[align=left](Amazing stuff. Definitely check out http://www.prescher.ch also )
FULL CREDIT AND SOURCE - http://www.prescher.ch/Collection/Tourbillion/MysteriousAutomaticDoubleAxisTourbillon/tabid/156/language/en-US/Default.aspx
Pictures from Thomas Prescher's Facebook page -
Mysterious Automatic Double Axis Tourbillon
by Thomas Prescher horological visionar [/align]
[align=left] A vision. That is normally the beginning of a time sculpture manufactured by Thomas Prescher. Guided by the idea to improve the perfect visibility of the central elements of his multi Axis Tourbillon Thomas Prescher composed a new breathtaking piece of art.
[/align][align=left] A mysterious kinetic Sculpture
Only time, Tourbillon, calendar and oscillating weight are visible. The movement is completely hidden. Place to hide the movement was found left and right in the case, hidden by the bezel. Because the space is very limited the parts of the movement had to be located on both sides.
Later, resting in a hammock the idea was born to create an automatic movement with horizontal swinging oscillating weight. To crown this exceptional piece of art, it was a logical decision to choose something special for the heart of this watch. The escapement with its beating balance has to be a flying Double Axis Tourbillon with constant force.
The idea to add a calendar to this creation came while observing some people entering a giant swing. They could move on the surface of the swing. Why not create an oscillating weight with integrated calendar indications and let the gravity take the calendar on the oscillating weight remains always horizontal.
This mysterious watch with its transparency led automatically to the wish to wear it from sides, front and back. With the calendar located on the flat side of the oscillating weight this indication is always facing upward. It can be read regardless of which side of the watch is up.
Respecting the aspects of harmony was an important point. Two crowns were used to keep the beauty of symmetry with. One crown is used for winding and the other for setting time and calendar. Both crowns build the main symmetry axis. Now it was necessary to build the optical balance between the oscillating weight on one side and the indication of time on the other side. For that reason a three dimensional moon was placed between the two barrels, indicating the hours and minutes.
Finally, placed on a turning axis, held by a carrying arm the carriage is rotating around itself. These two synchronized motions create a gyro scoping image immediately taking full attention. A mesmerizing kinetic sculpture is born.
