Hi,
Is there anybody know what is the level of grade of ETA7001 used in Stowa KS ? Standard , elaborate or top level ?
Thanks.
Off hand sounds like a quartz. As for level don't worry. It is a Stowa and if genuine will be fine. Google this, it is a way to learn. If a Rhonda you will get
Diagrams and more.
Part of the fun is looking for this yourself, no telling what else you learn stumbling around to net in search of watch lore.
Welcome as well
Discussion Starter #6
Thanks for the help, I have asked Stowa, the reply is that they use top version of 7001.
While some other poeple tell me that ETA does not categorized the 7001, only one grade on ground.
Is there any material tells about the detail spec of the movement ? I.e mateial of hairspring, main spring, balance wheel, pallet stone etc.
as I understand all 7001's are top grade(better main spring,real ruby jewels,better balance etc.),even the non decorated plain jane models.
the variations are the decoration level.
for the most part,if an eta movement has a flared balance wheel its top grade.
I don't recall what parts are different from elabore to top off hand,but I am sure some one here can add.
