How sneaky do you want to be?
We hear so often about the sad consequences of people having their privacy violated, so it’s always good to go the extra mile in protecting yourself. Whether this means adding that additional spy gear to your home or wearing your surveillance on your sleeve, you’ll be at ease knowing that this state-of-the-art Smoke Detector with Hidden Wi-Fi IP Camera will keep you abreast of everything that is going on around you. Equipped with the technology for constant 24-hour video surveillance, it is an affordable way to keep you and your belongings safe and sound. Invest in this high-performance gadget today!
Want to know more?
  • Lifetime supplier’s warranty and tech support
  • Compatible with Microsoft Win98 SE, ME, 2000, XP, Vista, or Windows 7
  • Small, WiFi-capable hidden camera, but you also have the option to place a MicroSD card directly into the device and record locally or view and record
  • Software includes many options for recording, including alarm recording, motion-activated recording, scheduled recording, or constant video recording for 24 hour surveillance
  • Image Sensor-600TVL CMOS, Color
  • Video Compression-H.264 high profile, JPEG/BMP snapshot
  • Signal System:NTSC/Pal selectable
  • Lens-3.7mm/4.3mm pinhole selectable
  • MIn.Illumination-0.1 Lux (IR OFF), 0 LUX (IR ON)
  • Frame rate-30fps NTSC, 25fps Pal
  • Resolution-D1 (720×480)
  • Video adjustment-Brightness, contrast, & saturation
  • Video bit rate-32 Kbps ~ 2.5 Mbps
  • Digital zoom
  • Measures 5.5″ x 5.5″ x1.75″
  • Recording mode-Motion detection, manual, and schedule
  • Record to local SD (up to 32GB, not included); record to remote PC; video or snapshot
  • Remote back up to PC
  • Playback via SD reader; real time remote playback; remotely download and playback
  • Motion detection-VMD (video motion detection)
  • Alarm reactions-Alarm photo email; record photo to FTP; record video/photo to SD
  • Network interface-10/100 Base Ethernet (for wired network connection)
  • Wireless network-Wi-Fi 802.11 b/g/n
  • IP mode-Dynamic IP address; static IP address
  • Protocol-TCP/IP, HTTP, TCP, ICMP, UDP, ARP, IGMP, SMTP, FTP, DHCP, DNS, DDNS, NTP, UPNT, & RTSP.
  • Online users-10 users at the same time
  • Mobile surveillance:iPhone® , Android
  • Internet viewing supports IE, Firefox, Chrome and Safari®
  • Remote access
  • CMS software:Central management software for recording, remote monitoring, remote access and control, search and playback, and up to 64 multiple cameras surveillance
  • User levels for CMS-Administrator, Normal, & Guest (viewing only)
  • Supports camera labeling for distinguishing cameras
  • Password protection
  • Operating system: Embedded Linux OS
  • Micro processor: 32Bit RISC embedded processor
  • Indoor usage
  • Operating temperature: 10 ~ 50 °C (+14 ~ 122 °F)
  • Humidity: 95% RH
  • Power: DC12V 1A
http://www.1sale.com/products/smoke-detector-with-hidden-wi-fi-ip-camera/
