[flash=425,344]http://www.youtube.com/v/FbmKZ5JXyjo&hl=en&fs=1[/flash]
http://www.azfinetime.com/Seiko-Spring-Drive?osCsid=2ae076298130b791d0f90826e4bc8883&gclid=CMmU6pKz1J8CFWEO5Qod-w7jcg
Seiko’s watch makers have always been on the forefront of manufacturing high quality, precision watches. And, they are constantly looking for ways to improve the accuracy of their time pieces.
With this in mind, it is known that the weakest part in any traditional watch mechanism is the escapement. An 'escapement' is the mechanism that releases the watch's gears and pushes the balance wheel to keep it moving. It is designed to advance the balance wheel a certain amount with each 'tick'. In 1977, to overcome this problem, Seiko engineer Yoshikazu Akahane, came up with the idea of the "everlasting watch". But it took another 28 years and many prototypes before Seiko finally achieved their goal with the international launch of the automatic Spring Drive line in September of 2005. In simple terms, they deliver unbeatable accuracy, that has the smoothest movement and an extra day of power compared to most. The Spring Drive has effectively three whole days of power reserve, and advertises to be accurate within one second per day (but is achieving accuracy equivalent within 2-3 seconds a month!). This is an accuracy achieved by no other luxury watches.
Seiko Spring Drive Chronograph watches also boast a two-step system for precise time measurement, and with a solid 'click' that captures the precise moment of starting or stopping of the timepiece - not just the nearest 1/10th of a second that many of it's rivals offer.
However, it is the regulation system that sets the Seiko Spring Drive apart from other timepieces, the balance/escapement mechanism being replaced by Seiko's unique Tri-synchro Regulator which regulates the unwinding power of the mainspring and converts a small part of the energy into electricity to power the quartz crystal. The third element, that gives its 'tri' name, is the generation of a magnetic force which regulates the speed of the glide wheel.
The Tri-synchro Regulator is not the only new technology employed in these magnificent timepieces. The mainspring itself is made from a new high-elasticity alloy called 'Spron 510', also developed by Seiko, and a new and more efficient version of Seiko's Magic Lever winding system which allows for a shorter winding period and longer power reserve. The modern innovation and elegant glide motion of this timepiece are captured in the design of their case, with the circular motion of the movement beautifully expressed in the circular motifs of the collection. The Seiko Spring Drive collection consists of four limited edition pieces - 2 Chronographs and 2 Moon Phases, with three regular models - the GMT, Center Second Hand and Small Second Hand, each with at least 3 face and strap variations - all with elements of the traditional, the modern and the elegant.
Seiko Spring Drive - Seiko Spring Drive SpaceWalk Limited Edition
#SpringDriveSpaceWalk
SEIKO SPRING DRIVE SPACEWALK LIMITED EDITION The Seiko Spring Drive Spacewalk Limited Edition watch is the firstwatch in the world specifically designed to withstand the rigo
Seiko Spring Drive - Chronograph Limited Edition
#SPS003
In 2008, a new steel interpretation of the Spring Drive Chronograph was released. With its unique glide motion and combining the quality and precision of modern engineering
#sps001
Luxury detailing. High tech materials. The Seiko Spring Drive Chronograph is the second of the Limited Editions from the Spring Drive Collection. First released in 2007,
Seiko Spring Drive - Moon Phase Limited Edition
#SNR017
2008 saw the launch of the second generation of the Spring Drive Moon Phase with another Limited Edition of 200, the first generation having all but sold out. The elegant moon p
#SNR011
Seiko’s Spring Drive collection has been receiving awards since their launch in 2005, including ’Watch of the Year’ from Timezone.com! This Limited Edition Moo
Seiko Spring Drive - Seiko Spring Drive GMT - Champagne Dial
#snr013
The Spring Drive G.M.T. watch is perfect for the international traveler. The G.M.T. hand can be set without disturbing the one-second-a-day precision of the Spring Drive
Seiko Spring Drive - Seiko Spring Drive GMT - Grey Dial
#SNR009
- Power Reserve Indicator - 72 Hour Power Reserve - Center Second Hand - 24 hour hand - Stainless Steel Case - Exhibition Case Back - Saphire Crystal with anti-reflective coating
Seiko Spring Drive - Seiko Spring Drive GMT - Slate Grey
#snr015
Seiko Spring Drive - Seiko Spring Drive GMT - White Dial
#SNR007
Seiko Spring Drive - Seiko Spring Drive Power Reserve - Black Dial
#snr005
- Power Reserve Indicator - 72 Hour Power Reserve - Center Second Hand - Stainless Steel Case - Exhibition Case Back - Saphire Crystal with anti-reflective coating - 10 bar
Seiko Spring Drive - Seiko Spring Drive Power Reserve - Blue Dial
#snr003
Seiko Spring Drive - Seiko Spring Drive Power Reserve - White Dial
#SNR001
Seiko Spring Drive - Seiko Spring Drive Power Reserve Small Second - B
#sns005
- Power Reserve Indicator - 72 Hour Power Reserve - Small Second Hand - Stainless Steel Case - Exhibition Case Back - Saphire Crystal with anti-reflective coating - 10 bar water
Seiko Spring Drive - Seiko Spring Drive Power Reserve Small Second - C
#sns003
Seiko Spring Drive - Seiko Spring Drive Power Reserve Small Second - W
#sns001
#SPS003
#sps001
#SNR017
#SNR011
#snr013
#SNR009
#snr015
#SNR007
#snr005
#snr003
#SNR001
#sns005
#sns003
#sns001
