This one is a store display that was handled but never worn. I cannot find a mark on it anywhere. Comes with all the tags and paperwork. From what I could find these are really hard to get in the states. PP or Venmo...Venmo preferred. $224 in your hand. Holler with any questions or if you need more pics. Thanks:)
Seiko Prospex LOWERCASE Produced Model SBEP011 - men's watch made by Seiko. It has Japanese solar quartz movement and S802 calibre. Polymer case of round shape. Case dimensions are 49.5 mm. in diameter and 14.1 mm. in thickness. The dial of this Seiko watch is lcd. Display type: digital. This timepiece has hardlex glass. Polymer band, band color: white. 200 m. water resistance. The watch is from Seiko Prospex collection. The following features are equipped: date, day, chronograph, countdown timer, alarm, perpetual calendar, world time, dual time, backlight.
  • Alarm
    The Alarm will remind you of repeated events with a beep, which you can set to any time.
  • Backlight
    The backlight is a dial illumination that allows you to use this watch in the dark.
  • Chronograph
    You can measure the amount of time between two events using this watch.
  • Countdown Timer
    Timer indicates the end of the time period you set.
  • Dual Time
    With this watch you will easily know local time in two time zones on your choice.
  • Perpetual Calendar
    Will automatically show you day, date and month, including leap years until the year 2100.
  • Solar Powered
    This watch can be charged from almost any light source and run few months or more in the dark when fully-charged.
SPECIFICATION
Brand Seiko
Collection Seiko Prospex
Movement Solar Quartz
Calibre S802
Case Material Polymer
Case Shape Round
Case Size 49.5
Case Thickness 14.1
Band Material Polymer
Water Resistance 200
Glass Hardlex
Features Date, Day, Chronograph, Countdown Timer, Alarm, Perpetual Calendar, World Time, Dual Time, Backlight
27A42D66-5E08-41C4-88C6-EDF06748B4E5 by Brad Sotak, on Flickr
1AD71202-6268-4E44-91DE-591F9FDE6779 by Brad Sotak, on Flickr
ED3FAAEB-9663-4819-8C2E-CD9FF635D292 by Brad Sotak, on Flickr
B3FAD821-4A09-4014-A218-63720C65FC57 by Brad Sotak, on Flickr
A8C3A4A4-465A-4E37-AA76-3880F15296CF by Brad Sotak, on Flickr
6ED1F491-8038-4A23-B831-1F47D96FC48A by Brad Sotak, on Flickr
Reactions: rh747m
Watch Freek
I'm not much into digital watches but this one is interesting. 👍
Reactions: Brad
ttt
