1 - 5 of 5 Posts
Good evening all. I have just started to wear my old Citizen cal-3510 which is just over 18 years old. It has not had any wrist time in about 5 years. Before I mothballed it, I took out the battery to prevent any leakage. I have now fitted a new battery & the watch came back to life. The time keeping is very accurate, just like new. On testing the chronograph function, I noticed the 1/50th's second hand did not rotate, even though the seconds counter & minutes counter hands operated ok. After wearing it for a few hours, I found the 1/50th's second hand started to work intermittently in a stuttering way not quite keeping up in sync with the seconds counter. On the odd occasion it works just fine. Do I just accept the movement is bust, or is there an easy solution? Cheers!
Wish I could help (I have a few Citizens, all running but no Chronos - thankfully) but all I could suggest would be to see if it improves "with time". If not, send to Citizen which people have said on various forums offer pretty good service.
Thanks for those replies. I have been wearing the watch for a couple of days now, & it works perfectly without fail whilst on the wrist. If I take it off the wrist & leave it a couple of hours, it plays up like described in the original post. So from what I can gather, it would seem like it only works correctly when warm or at body temperature. I think it may possibly be something to do with the lubricants in the movement after the watch not being used for years. Hopefully if I keep wearing it & operate the chronograph function regularly, it will 'wear it in' & redistribute the lubricants. I'm hopeful, but that's my best guess! Is my 'guess' possible, or am I over simplifying it?
Sounds like a little bit of dry lubricant is in your movement. Those things tend to happen after 18 years of sitting around. I suggest you send it to Citizen for a service and a cleaning. I'll bet that fixes your problem.
1 - 5 of 5 Posts
