Invicta Reserve Men's Specialty Subaqua 5215
Invictas specs.
•Bracelet: Stainless steel
•Movement: Swiss ETA 251.272 quartz chronograph
•Crystal: Flame Fusion
•Crown: Screw down w/ function pushers
•Clasp: Deployant
•Bracelet Measurements: 9" L x 31mm W
•Case Measurements: 52mm
•Water Resistance: 50 ATM - 500m - 1650ft
Heres my specs. weight,373.2 grams.okay, thats just plain heavy.
Case diameter excluding crown.52mm.
Height.20mm
lug width.25mm.
lug to lug.I measure this from what will contact the wrist.not the overall
length.its 52mm.The lughorns are down turned, making this one fit, at least
my own wrist which is 7 1/4.
bracelet width.31mm at the lugs and tapers to 26mm at the clasp.
bracelet thickness.5mm.
non rotating bezel.The bezel screws are only for the bezel attachment.
This watch uses a cage to support the mid case by using 4 screws.2 at
9 oclock and 2 at 3 oclock.remove those and the bezel and the case will
slide out of the cage.
Dial.Really nice,Invicta does dials better than any other company,
especially the mother of pearl dials.most of those are done using Australian pearl.
markers, numbers and indices on the dial.Again, very good.legible with
no bleeding.
flame fusion crystal.No idea what that is.But its stated that this crystal is
triple ar coated.I don't doubt this as the blue really shows.
caseback.Pretty good.But Invicta doesn't tighten the screws enough and you'll
need to check those when it arrived.
crown and pusher.Very good.These function as they should with no play
in the crown stem.
clasp.Again, this is done very well using the standard clasp with a flip lock.
So far, this watch is really scoring well.About an 8 out of 10.But
there is a huge problem with these.The attachment point to the lugs.
Theres 3 methods for doing this.Friction pin,springbar, lugtube and screws.
I guess theres now 4.For this series,Invicta decided to use a tube with
a fake screw.These push in and over time will fall out.Theres no threads
on these.For mine,I applied a liquid metal welder to them so they won't
pop off.Another glaring fault is the use of tritinite as the lume.
This wouldn't be much of a problem if it was applied evenly.
I'll need to send this to kent parks and have c-3 luminova applied.Whats
on it now is junk.
In conclusion, my thoughts about this watch only.Its very well built and
worth what I paid.Even with the faults listed, I'll be keeping this one.
Invictas specs.
•Clasp: Deployant
Height.20mm
lug width.25mm.
no bleeding.
in the crown stem.
on it now is junk.
