Hey gang,
Wondering if anyone has any advice on a band I can use to replace the one that has disintegrated on my 52MM Bolt original, this thing just fell a part after 5 years, and I barely wore it, but we all know Invicta is not the standard when it comes to great bands, and I cannot find the stainless/rubber band anywhere, so looking for a suitable replacement band, or another model that may fit it, because the watch is great and intact, but the band is garbage now! I expected this thing to not be so easily destroyed just from sitting most of the time!
Its hard to find these bands, I've looked everytwhere I can think of, and they are not in stock at Invicta either :(!
malbak
I have an idea the Bolt you own is the same as the one I gave to my SIL.
Strap separated a few mms south of the lugs.
I called Invicta and was placed 24th in line to be heard. Waited 40 mins
and was told a repl OEM strap was $75.00 (+ shipping) Gee thanks Eyal and
your band of 40 thieves.
Took Bolt to local Mall strap shop. They found a 28mm strap @ $40.00.
The Bolt I have had dual spring bars on each lug. Stygean effort to install.
But strap tech mounted it in less than 6 mins. SIL says after market strap
is better than the original.
Acomplished 2 things. 1. Buy no more Bolts 2. Buy locally. Keep your cash
in the area.
Hmmm, I have been looking at other types of straps, but was unsure of the type I should get, but if it is 28mm that will help narrow it down, as Eyal and his thieves will no doubt try and take more than their share! Do you happen to know what type strap he got? Its definately my last bolt, or any watch from Invicta that has a poly strap, if any at all, and I have a few, and another Reserve gunmetal band broke too, with no way to fix it properly without getting raped by Eyal!
Thanks!
malbak
in the area.
