To make Vimeo videos work in posts on this forum you have to use the code shown below. This does work and the videos will play once downloaded if you do the code correctly.
Here is how you do it.
You must use this exact code shown below.
Code:
[flash=400,225]http://vimeo.com/moogaloop.swf?clip_id=INSERT VIDEO ID NUMBERS HERE[/flash]
So for example to make the Oris watches video found here - http://vimeo.com/7413478 - show in a post on this forum - you would simply take the ID number of 7413478 and insert it into the code shown above.
That would make the code you type into your post look like this -
Code:
[flash=400,225]http://vimeo.com/moogaloop.swf?clip_id=7413478[/flash]
And if you put it in a post it would look like this -
