I am having a hard time getting the master calendar set. I can set the day or the date, but can not set both. Currently I have the date right but the day says Sat when it is Tues. Any ideas how to fix it?
You need to set each one independently to the day and date which is the day before the current date. For example, let's use today...Tuesday 12-29-15. Set the day to Monday, then the date to the 28th. Then pull the crown all the way out and rotate the hands clockwise until both dates change to Tuesday the 29th. Then set the time
The 5040F movement has recessed pushers on both sides of the case you use to set the month, day of week and date independently. Use a pen or such to push them.
