Glycine F 104 Automatic, Manual, and Pocketwatch
6206 Views 5 Replies 4 Participants Last post by  FalconWatch
Conceived in the fashion of a cockpit instrument, this extraordinary model is impressive with its pure functionality. The watch features a stainless steel 52mm case housing a Unitas 6498 manual wind pocket watch movement.
A domed exhibition back attached securely by six screws allows for a full view of the sturdy movement.
The case, despite its extraordinary size, is anatomically designed and conforms to any wrist by use of articulated lugs.
A pyramid shaped 9mm double o-ring crown lends to the antique look and touch long missing from today's fine timepieces.
Main page on Glycine site - http://www.glycine-watch.ch/e/collection/collection_overview.e.jsp?ID_Group=100005
Automatic -
Movement
Caliber: ETA 2824-2 automatic
Functions: hours, minutes and seconds, date display in window
Jewels: 25
Power Reserve: 38 hours
Hz: 4/28'800 vibrations per hour
Finish: nickel coated oscillating weight on ball bearing decorated "Côtes de Genève"
Case, Dial & Hands
Material: stainless steel
Diameter: 48mm without crown
Height: 9.60mm with see through back
Finish: polished
Waterproof: 3 atm
Back: screwed see-through mineral glass
Glass: sapphire
Dial: black with SL, silver with SL
Hands: white with SL, black with SL
Crown: sticker crown
F 104 Manual -
Movement
Caliber: ETA 6498-1 3 hands manual winding
Functions: hours, minutes and small second
Jewels: 17
Power Reserve: 46 hours
Hz: 2.5/18'000 vibrations per hour
Finish: diamond finish on ratchet and crown wheel, visible screws in blue finish, bridges rhodium-coated, decorated "Côtes de Genève"
also available with following finish:
nickel coated, bridges chess board decorated
Case, Dial & Hands
Height: 9.6mm with see-through back
Finish: polished
Waterproof: 3 atm
Glass: sapphire
Dial: black with SL
F 104 Pocketwatch
Movement
Caliber: ETA 6497-1 3 hands manual winding
Jewels: 17
Hz: 2.5/18.000 vibrations per hour
Finish: nickel coated, bridges chess board decorated
Case, Dial & Hands
Diameter: 52mm
Height: 10mm with solid back
10.50mm with see-through back
Finish: satin
Waterproof: 3 atm
Back: solid steel screwed / screwed see-through mineral glass
Glass: K1 mineral
Dial: black with SL
gawgiz timepieces, daahlink :c
is that model number actually on the dial, or just in the pictures
The "referance' number i.e. 3896 is engraved on the back...
