SOLD REDUCED to $900 – PP fees and CONUS shipping included. International shipping is a possibility we can discuss. No trades please.
I believe there are a total of 100 Oceaneers, and only 30 or so with the yellow second hand. This one is serial #38. I am the third owner. There are some very, very minor marks on the bead-blasted finish here and there. There are also some typical light scratches on the caseback and lugs. I mostly wore this one on a leather strap – so the bracelet is in great shape. Check my pics. Bracelet is sized to my 6.75” wrist, but all links are included in the full kit. I also purchased an extra bezel from Poul while a scuff on the original was getting buffed out by Jack at IWW. The second bezel has slightly different font (taller numbers) than the original so it’s a bit of a varied look, which is cool. Crystal is perfect. Poul recently serviced the ETA 2892-A2 movement for me, and it is running very accurately. The best part: This watch is still within its 2-year warranty until 2/20/2016!
Specs from Korsbek:
Case: German Made (Fricker). Surgical Grade Stainless Steel 316L. Bead blasted. Inner case made from soft iron (cylinder, back plate, dial plate) for anti-magnetism.
Movement: ETA 2892-A2, Swiss made mechanical automatic, 21 jewels, Incabloc integrated shock resistance system, 42 hours power reserve, 28,800 beats per hour, hacking.
Functions: Hours, Minutes, Seconds. Quick set Date at 3/4 o’clock position.
Dimensions: 45 mm Diameter bezel end to bezel end, 54 mm lug end to lug end, 24 mm lug width, 17 mm height overall
Crystal: Extra thick Sapphire (scratchproof), domed, anti-reflective coating (inside only)
Crown: Screw-locked, signed.Bezel: 60-clicks, rotating, unidirectional (counterclockwise) bezel with black inlay
Case back: Stainless steel, engraved and screw locked with double O-rings. Individually numbered
Bracelet: Bead blasted stainless steel. Solid end links. Micro-adjustable flip lock clasp with an integrated diving extension feature
Ratings: Water Resistant 1000 meters (3300 ft with crown screwed down); antimagnetic (80,000 a/m); shock resistant; pressure-proof to 100 atmospheres
My watches are all gentIy worn, clean and well taken care of. I have many successful sales here on the forums (WUS: flyersandeagles / WF: dsfeight), and over 15 years of perfect feedback on eBay (user ID: flyersandeagles).
Attention: Please ensure that you have a solid, documented history on the forums or the Bay before contacting me about this watch. I have been private messaged by at least 5 potential "buyers" that have contacted me once, and then disappeared. Then I noticed later that they have no posts and no history on the forums. I've been selling watches here for years, and have not run across this problem as much as I have while trying to sell this watch, for some reason. Please understand that I won't be replying to your message if you have no posts and no history on the forums. Sorry, but I have wasted a lot of my valuable family time on this already. Thanks for your understanding.
Please let me know if you have any other questions or need more pictures of anything. Again, I’m not accepting trade offers – watch is for sale only. Thanks for looking! Onto the pics, which were taken tonight...
Sent from my SM-N900V using Tapatalk
