I have an Eco Zilla that I wear regularly but haven't worn for a few weeks as I've been working away. Upon my return I noticed it had stopped, so I left it in direct sunlight for well over 24 hours, but still no charge.
Any help would be gratefully appreciated.
Discussion Starter #3
Cheers dude just emailed the service department. Hopefully it won't be too costly.
Try and pull out crown to reset it first, see if it starts up?
Sent from my iPhone using Crapatalk
Definitely try this (a couple of times if you have to). I was in the same situation, charged mine in sunlight for a couple of days and it was still doing the 2 second jump. Someone on here provided this guidance and as soon as I pulled the crown and reset the time, it started running like a charm.
Yeah try the reset first, that might do the trick. If not send it for service.
Discussion Starter #7
I've had the crown out for 30 seconds then reset the time all whilst in direct sunlight. Still nothing. Shall I pull the crown out and try charging it for a while like that?
Pull the crown in and out 2-3 times gently. If it doesn't start working you just might have an issue. I don't think charging it with crown out will make a difference
Discussion Starter #10
That post is nothing to do with ecozillas haha
Discussion Starter #11
Cheers dude.
