I recently purchased a watch off eBay with broken stem I have cleaned and then dissolved stem in alum powder and replaced with new stem movement is e168 so stem not to hard to find hope you enjoy the pics
Automotive tire Camera lens Camera accessory Motor vehicle Reflex camera
Watch back with broken stem
Water Liquid Drinkware Solution Fluid
dissolving stem in alum powder mixed with water put this jam jar in pan of boiling water on heat source and 10 hours later over 2 days you get a crown minus stem if crown is stainless steel.There are alternative methods if you have lathe or tools and I did this once before leaving by boiler but took 3 weeks heat helps.
Wheel Automotive tire Rim Gas Bicycle part
Arthropod Insect Organism Grey Wood
Old stem and new stem next to nice clean crown.
Light Wood Line Material property Font
crown with new stem cut to length and tested the loctite thread seal used and seals put back .
Liquid Solution Cosmetics Fluid Bottle cap
Drinkware Grey Silver Camera accessory Font
case back cleaned and seal lubed.
Watch Analog watch Clock Grey Font
watch all back together happy happy 馃槉
馃槷馃榿Holy cow, that is some really fantastic work Nomad ! (y)(y)
I love how you knew just to do all of this, or found out how to do
everything. Incredible stuff ! 馃槻馃榾And how about the end result?!
Now you have a flawless stem back on that spectacular Citizen,
which is ready for some serious wrist time now I bet. Well done.
Man oh man, this was just THE best to see, as well as follow along
with Nomad ! ..Thank you so very much for this post !!!
Discussion Starter · #3 · (Edited)
Thanks Atomic Tom had to do a lot of research working on various watches so thought might help someone else.
I think I鈥檓 a horologist addict lol.
Thanks atomic Tom had to do a lot of research on various watches so thought might help someone else think I鈥檓 a horologist addict lol.
Don鈥檛 mention it. 馃檪 And thank YOU for doing all of that research,
as well as thinking to help people out like this. 馃弳馃 ..It really was
so nice of you to do. (y)(y)
Thanks a ton once again for taking the time Nomad !
