C300 ALL RESET issue
17220 Views 6 Replies 4 Participants Last post by  Goramos
I have a Citizen Navihawk Blue Angels with a C300 movement. I recently changed the battery and have followed the instructions (or thought I had) on the inside of the case to short the AR with the + side of the battery. But in doing so nothing is resetting to zero. Right now I am unsure exactly what the AR is, I thought it was the bottom contact in the row of 4 contacts above the AR lettering. Can someone help with how to do this and reset it all back to zero. Thanks in advance.
Reactions: 1
1 - 7 of 7 Posts
Maybe this will help
Thanks for that Tinknocker. After I pull out the bottom right button one stop and then hold down the remaining three buttons i don't get the all 8s in the Screens as I should. Maybe I should consider Replacing the C300 movement.
Could it possibly be that one of the pushers isn't functioning, or maybe intermittently because of dirt or something.
I found this vid that seems to have more info, which may help.
Also the instruction manual, if you don't have one. Just enter C300 at the left.
http://www.citizenwatch.com/en-us/support/setting-instructions/
Thank you for your suggestions. What I have realised is that I can't get the digits to reset and flash. I think it is a digital problem. I have cleaned the buttons, etc. I think Eslinger has the movement for sale, but I don't know if this includes the digital and analogue face.
Citizen Navihawk c300 no display
Im having a similar issue . Watch has been in storage for years and needed a new battery. i have tried to put one in and attempted the ar n + on the battery to ground it but nothing seems to be bringing it back to life the display is blank, any ideas please?
I did as the video recomends and I was able to set the watch right, thank you
1 - 7 of 7 Posts
