1 - 10 of 10 Posts
Designed by Marti Guixe for Alessi blank wall clock has no markings at all. It has a write-able surface that can be wiped clear. You can write on the face of the clock with a wipe clean pen. Different hours are represented with the help of words and IS is written in the middle of the clock. The IS helps you connect two words, making a sentence, so that you have a new sentence every time you see the clock. It is a perfect design to have fun with time.
Read more: http://www.homeqn.com/entry/blank-wall-clock-measures-time-with-sentences/#ixzz0m4aVw2LD
I really like that, but can you actually buy it?
Blank Wall Clock by Martí Guixé is an exclusive Alessi Spring/Sunner 2010 collection that is so simple and it looks cool. Made from aluminum, this white wall clock can be personalized just by using an ordinary marker. One convenient thing about the Blank Wall Clock by Martí Guixé is that if you use an erasable marker you can prepare some notes or reminders on the face of the wall clock and change it everyday. $TBA.
There is a store RIGHT by me in Raleigh that sells it. Cool, going to call them tomorrow and see if they have it. Thanks!
Discussion Starter · #10 ·
1 - 10 of 10 Posts
