1 - 10 of 10 Posts
Hi guys.
One of my watching AR coating looks like it was scrapped off, not completely but very lightly. So I was wondering can the AR coating be redone on a watch without changing the crystal?
Reactions: ganson
You know that is a really fantastic question Abdullah. :smile-thumb: Have always honestly wondered about this too. ..Hopefully someone has some experience with this, and can help you out here with this sir. :thumb: :)
Good to see you my friend, your absence has been noticed.
With an exterior AR coating? Not sure if it could be re-applied, but it would be possible to polish it off.
Maybe someone else has some experience with this.
It can't be reapplied.You must replace the crystal. I try to avoid watches with the external coatings as a result.
Reactions: Abdullah and ganson
Reactions: Abdullah
I'd just remove the external AR Coating and be done with it
Discussion Starter · #8 ·
Yeah I was busy maintaining this new business, never new it will be so much work to make a new business self-sufficient :)
The watch that's crystal AR needs redoing is the TAG AquaRacer. So if I want to do it I'll have to send it to US and there give it to someone.
It's not visible until you look at it from a certain angle. So should I leave it as it is or send it to be redone?
Reactions: ganson and cmann_97
Truthfully, I would just have the outside AR removed, the difference in appearance will be negligible.
Reactions: cmann_97
I would have it removed by a professional. If you send it to the U.S., have International Watch Works do it for you. Jack is awesome.
Congratulations on your new business!!!
1 - 10 of 10 Posts
